Advice On Restoring Of Front End Please.
5 replies to this topic
#1 myminipickup
myminipickup
  • 152 posts
Posted 04 October 2015 - 06:28 PM
Hello.
I am looking for some advice/help on removing and replacing the front end of my Mini Pickup. I am currently restoring it, and now I am at the point where I need to remove the front A panels, wings, and front end. I was hoping to keep the inner wings as they are not too bad, although the passenger side one is bent at the front, but hopefully I can straighten it.
Attached File  SAM_1656.JPG   76.02K   14 downloads
I want to try to keep the front panel, as its the original pickup front panel with the pressed grill. Its a little rusty and has been repaired in the past, so it probably full of filler. I was planning to remove it and have it dipped or sandblasted, then see what I have to play with.
Attached File  SAM_1671.JPG   80.73K   7 downloads
Attached File  SAM_1670.JPG   69.28K   5 downloads
Attached File  SAM_1677.JPG   61.02K   8 downloads
At the same time I was hoping to dip the bonnet.
So I want to try to keep the inner wings and the front panel, but how do I remove the front panel without damaging the mounting bracket panels?  Or do you know if can buy these mounting panels?
Attached File  SAM_1653.JPG   68.76K   8 downloads
Attached File  SAM_1655.JPG   63.82K   9 downloads
I am going to replace the A panels and wings.
Any other suggestions or advice would be great.
Many thanks.
#2 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 04 October 2015 - 06:39 PM
i think this requires a comment of if you do nut have a clue about what your doing then leave along until you do the inner wing will straighten, but really if you have no idea get someone who does to do it or help you in person
#3 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,017 posts
Posted 04 October 2015 - 06:40 PM
I would chop the majority of the wings and a-panels by the seams. you should then be able to get to all the spot welds to drill them out.
#4 Daz1968
Daz1968
  • 2,058 posts
Posted 04 October 2015 - 07:11 PM
I just bought some dormer cobalt spot weld drill bits off eBay £4.99 each I think and so far seem ok, just avoid the cheap I branded ones, as above of you cut off wings inboard of seams then the front panel will easily come off with a spot weld drill, if your front panel is to bad then you could weld your grill area into a new replacement one.
Edited by Daz1968, 04 October 2015 - 07:11 PM.
#5 Jools33
Jools33
  • Validating
  • 56 posts
Posted 04 October 2015 - 07:23 PM
Don't remove too much at once. You need datum points to position the replacement parts. I take photos as I go along as memory joggers, useful if the restoration is over a long period.
#6 myminipickup
myminipickup
  • 152 posts
Posted 05 October 2015 - 07:26 AM
Thanks for your advice.
Does anyone know if you can buy the panels that hold the front end onto the inner wings?
