Time to add a few more pictures of progress. Rear o/s corner repair panel tacked in place.
Welded up.
Posted 15 October 2015 - 08:25 PM
Even more cutting.
Posted 18 October 2015 - 08:13 PM
Next job fit the sill strengthening to the car.
Posted 18 October 2015 - 08:42 PM
Posted 22 October 2015 - 08:38 PM
Next up on the job list is the rear subframe. The subframe is brand new but painted in hammerite but got covered in wax oil so has picked up dirt and has been built up with stainless steel nuts and bolts and even titanium brake adjusters (stainless not available). Here it is with my sons restored adjustarides installed, new adjustable camber/tow plates, minifin brake drums and braided hoses. All ready to put back on the shell to allow the o/s mounting points to be positioned.
Posted 22 October 2015 - 09:14 PM
Nice work !
Wouldn't mind an estate one day
Posted 28 October 2015 - 07:53 PM
On with the fabrication of the o/s/r wheel arch. I hadn't been looking forward to this as the n/s was a swine to fit but at least I had an idea of how to make it. First up cut a piece of metal and bend it to fit.
Posted 05 November 2015 - 10:35 PM
Next installment. Finishing off the o/s/r wheel arch.
Starting with tacking to the body side.
Posted 09 November 2015 - 04:09 PM
great to see your bringing her back to life.
Posted 23 November 2015 - 10:51 PM
Time for a quick update. Been putting this off for a while. Fitting of the o/s floor.
After a day of fitting, removing, trimming, refitting, removing, trimming and so on it finally fitted.
Next job to start designing and fabricating the floor cross member. The original was more weld and patches than original metal as it has the seats bolted to it and was constantly cracking under the pounding of rallies. That in mind a plan was hatched which needed a small mod to the transmission tunnel.
And here is the plated hole.
And with a spot of etch primer and starting to weld the floor in.
Posted 27 November 2015 - 09:39 AM
Coming along nicely.
Posted 30 January 2016 - 01:12 PM
Been a while since I posted as I haven't had much time on the car recently.
Started on the floor cross member.
IMG_0163.jpg 53.06K 1 downloads
IMG_0164.jpg 47.43K 4 downloads
IMG_0170.jpg 69.71K 0 downloads
IMG_0173.jpg 58.73K 8 downloads
Edited by Itsjustanestate, 30 January 2016 - 01:33 PM.
Posted 26 March 2016 - 11:35 AM
Managed to get back on the car over the last month after the winter lay up.
I upgraded the door hinges to have 8mm stainless steel studs. No more seized nuts, these should last the test of time!
Needed to get these done so that I can get the old door pillar cut out and ready to take the new door pillar.
But before I weld it all up I had another job to do.
Make one of these!
It fits here.
Just need weld it on to the cage now and I can get back to the door pillar and fabricating a jacking point in the sill.
Edited by Itsjustanestate, 26 March 2016 - 11:35 AM.
Posted 08 April 2016 - 05:37 PM
All welded up now!
