Front Panel To Inner Wing Fitment
8 replies to this topic
#1 Stu.
Stu.
  • 912 posts
Posted 10 October 2015 - 09:36 AM
Hi TMF.
I'm mocking up my front end panels and cannot decide which side the tab is supposed to go on from the front panel to the inner wing.
The inner wing has a section of seam removed which appears to line up with the straight tab of the front panel suggesting the tabs goes on the inside (engine side) of the inner wing and the ears go to the outside.
Could someone please confirm. Thanks in advance.
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 15,885 posts
  • Name: Neil
Posted 10 October 2015 - 09:48 AM
Both the tab and ear will be on the outside of the inner wing.
#3 Stu.
Stu.
  • 912 posts
Posted 10 October 2015 - 01:05 PM
Thanks, so what's the cut out for on the inner wing seam then?
#4 Tupers
Tupers
  • 4,105 posts
Posted 10 October 2015 - 02:13 PM
Which seam are you referring to? Have you got a picture?
#5 Stu.
Stu.
  • 912 posts
Posted 10 October 2015 - 05:15 PM
Yes. Below is a photo I took of the tab located within the cut out (engine side of the inner wing).
Photo below shows it. Not quite aligned vertically but this is what I'm querying. To me the cut out seems to be to take the tab of the front panel. The ear is still in the outer side of the inner wing.
And this photo shows the cut out in the inner wing.
From what I can tell this should be where the tab slots in.
#6 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 11 October 2015 - 08:39 AM
the tab is to weld to front panel top rail
the front panel tags go on the wheel arch side
dave
#7 Stu.
Stu.
  • 912 posts
Posted 11 October 2015 - 05:04 PM
Thanks Dave, but I still cant understand why the inner wing seam has the long gap the same length as the tab of the front panel in it.
I've checked my 79 Mini and both the ear and rectangular tabs are on the outside as yourself and Neil have confirmed (wheel side of the inner wing), but I still cant understand why the inner wing has this gap in the seam. It must be for something otherwise they'd have run the seam all the way to the bottom surley.
#8 sonikk4
sonikk4
  • 15,885 posts
  • Name: Neil
Posted 11 October 2015 - 07:48 PM
Nope just the way the panel is built. You can look into something like this too much especially if you are an engineer by trade.
#9 Stu.
Stu.
  • 912 posts
Posted 11 October 2015 - 10:25 PM
Ok thanks Neil I'll keep em on the outside then. Stuff like this drives me nuts :)
