Soldiering on with Willy but sometimes hanker after the conveniences of a modern vehicule. Finally got my A/C sorted - summer lifesaver.
- one hose was poor and an 'o' ring needed replacing
- the compressor was tired and was replaced
- finally the relay wouldn't cut in ( voltmeter reading was 13.? at the alternator, 12.? at the starter motor but only 11.3 at the relay) but if you jumped the fan relay the fan would would come on and same for the compressor
- cleaned up the fittings around the fuse box (passenger side under bonnet) and all is good now
thinking of swapping in an upgraded alternator to pump more juice into the system. Once that is sorted next up will be putting in new valve guides and seals - hopefully
