G'day forum members,
I know I have discussed this before however I had some developments and need some final advice.
The Car
Reconditioned A+ 998 converted to unleaded (most likely a Metro engine from around 1985)
RA40 exhaust system with extractors ( bought as a stage one kit)
Twin 1 ¼” Carby’s with ABC needles
Pancake filters
65DM4 distributor with the GLC143 coil
Fuel is delivered through an electric pump through a filter king regulator at 3.5psi
Fuel bowl levels are fine.
I have 2 options with this car.
I can set the car at 5 degrees BTDC and the car will idle perfectly but it will not drive well.
Or
I can advance the distributor off scale, I would guess 30 degrees, and the car will run excellently but will idle like rubbish.
At 5 degrees, when the car is driven, will struggle like the engine is labouring under its own load. The car sounds like it wants to die and car stumbles like its running out of fuel. So in saying that the fuel side of things are fine. I can rule this out because I can advance the timing and the car runs fine.
I can’t find a happy balance between the two.
Until now I have focused on the electrical side thinking it may have been the ignition system. Everything on the electrical side stacks up and other than the timing side of the electrics it all seems to test correctly.
On advice from a retired carby guy I was told that the issue is that the Carby is not getting rich enough, fast enough. He based this on 2 main reasons.
1. When idling perfectly at 5 degrees when I lift the piston in the carby 1/32" the engine wants to die where it should slightly increase in revs
2. When the car is struggling I can pull out the choke and the engine improves to a near perfect level
He recommended that I get needles that have a slightly higher start point to get the carbys the correct mixture from the start.
So has anyone had a similar situation that they have managed to sort out? and more importantly can anyone recommend a needle that will give me a higher start point? I sure that selecting a needle that gets really rich towards the end of the range will also cause a whole new set of issues which also hope to avoid. I have looked over dozens of needles however I really need some guidance from people who know how they perform not just what looks richer on paper.
Thanks to everyone that has help out so far. It has been helpful and got me to this point which I hope is near the end.
