Is Anyone Running A Dash 2 With S60 Management System
Posted 25 November 2015 - 09:13 PM
Posted 26 November 2015 - 10:09 AM
I'm running one with an S40 pro but I'm pretty sure they can't be that different! You do need an interface cable that connects between the two items; on mine I'm pretty sure its just 2 wires. The outputs from the ECU to the Dash2 will depend on what sensors the engine has and if these have been wired to the ecu. You can get additional sensors for anything that isn't supported by the engine as standard. The only additional ones you will need are a wheel speed sensor for the speed input and potentially a pull up resistor to get the correct fuel reading; this will depend on what fuel sender you are using though.
Posted 26 November 2015 - 01:19 PM
Posted 26 November 2015 - 08:17 PM
The setting up of the dash is pretty easy, the hardest bit I found was calibrating the fuel but you're OK on that front.
Do you have the S60 wiring details? If so have a look through and you should see that pin one = oil pressure for instance so have a look at the connector in the car and see if that ones wired; by checking all the pin outs in the instructions against the ones in your car you'll be able see what sensors have been wired.
I have a Volvo engined mini so cant tell you what outputs your engine can do without requiring extra sensors.
If you don't have the manual they're all on their website.
