Gear Cables Help Please
Posted 01 December 2015 - 07:10 PM
Posted 01 December 2015 - 09:37 PM
Theirs a few companies out there that can make up gear cables and handbrake cables etc if you do have an incorrect size.
Posted 02 December 2015 - 05:39 AM
Posted 02 December 2015 - 08:06 AM
Try Speedy Cables.
Posted 02 December 2015 - 10:45 AM
Can someone please tell me what size the gear cables are on a vtec with zcars tunnel I have 1 shorter than the other it doesn't reach the gearbox does anyone have any of the right cables or know where zcars got them from thanks
I have a complete set for VTEC. It was swapped by another set by ZCars during the build of my diesel ZCars (I needed a longer set for the TDI engine).
I can send them over to the UK if you take care of postage charges...
Posted 02 December 2015 - 12:00 PM
Posted 04 December 2015 - 09:37 PM
Been very busy last couple of weeks
Just seen this
The rack in z cars stores has 2280 mm and 2260 mm written on where the v tec cables were hung
From memory they were two different lengths
If that helps
I can get new ones done if needs be if you end up stuck from where we used to get them from
Chris
Posted 05 December 2015 - 06:26 AM
Posted 07 December 2015 - 05:37 PM
I used to make a blanking plate to slip under the selector on top of the gearbox so you couldn't accidentally get first and second when really pedalling the car hard
Coming down from fifth and getting second instead of fourth gets exciting
