Vtec Won't Start
Posted 13 December 2015 - 01:27 PM
Posted 13 December 2015 - 06:36 PM
Posted 14 December 2015 - 07:09 PM
Posted 15 December 2015 - 07:39 AM
For trial and error purposes could you wire the ingnition switch to only the engine loom? Doesnt the ECU switch to ground for the injectors?
Posted 15 December 2015 - 10:15 AM
Posted 15 December 2015 - 01:13 PM
Edit: this is only my opinion from what you have said, I haven't the knowledge about the Honda injection system specifically so that may not be correct for your car
Edited by Alex_B, 15 December 2015 - 01:15 PM.
Posted 15 December 2015 - 06:09 PM
Posted 22 December 2015 - 06:29 PM
Posted 23 December 2015 - 12:52 PM
Might I suggest you also double check the connections to your MAP - MAF - IAT - TPS sensors and also the IACV.
My IAT was missing and it would run like a B45t4rd, coughing n spluttering then eventually dying.
Anything's worth a try right now. Good luck.
Posted 23 December 2015 - 01:05 PM
Posted 24 December 2015 - 08:25 AM
Get the IAT for it and then try it, it was a night and day difference on mine. I guess the only difference is I am using a Hondata ECU??
IAT can be found here: http://japservicepar...electrical.html
Edited by cptkirk, 24 December 2015 - 08:26 AM.
Posted 27 December 2015 - 07:22 PM
Posted 09 January 2016 - 06:31 PM
Posted 09 January 2016 - 06:54 PM
That's good to hear.....I bet you're feeling a whole let better about the project now.....
Posted 09 January 2016 - 07:01 PM
