Decided to keep 13" wheels on the mini as everything els just looks to big to me only problem is that 13 inch wheels will not fit over the mgf rear arms. So the solution is going to be to put front suspension on the rear I have a spare front subframe so I will swap all that over when I get two minutes. Manages to wedge a 13" metro wheel on the rear to help line the shell up.
So when it come to ling the shell up I pushed what's left of the build head up to the subframe and assumed that was right because no one modifies the front lower bulk head to fit a metro frame. But I was looking at the arch positions and the shell just looked to far back �� then I clicked that running a metro subframe the wheels sit 13mm forward doesn't sound like much but it was enough to throw the hole arch out so I had to re cut the cage out only tack welded on thankfully cut some more of my bulkhead away but this then gave me the room to slide the shell forward 13mm I also gained 13mm of engine space doing this �� winning so this is how it sits now
From the side
Metro wheel sitting in the arch smack on
I was quite curious if the door would fit after all this cutting very much to my suprise it fitted quite good verry happy with that
Door jam
Got a bit exited when frankinestine had part of a face
Now with the cage welded into its final position the shell needed to come back off to finish space framing only think is my garage Roof is not tall enough to lift it off so made the most of the wheels on my much evolving bench
Spot the difference �� time to start spaceframing
Need to get my hands on some steel now and
crack on
Edited by DrFrankenstein, 20 January 2016 - 11:25 PM.
