Zcar Vtec Type R Track Project
32 replies to this topic
#1 Luigi33
Luigi33
  • 79 posts
Posted 12 January 2016 - 08:35 PM
Amazing what you can pick up on ebay these days. I went on to look at R53 cooper S for a track car and ended up buying a Zcar mini VTEC.
This is the first day it came home:
It needs a clean under the bonnet:
The K20 type R engine:
#2 Luigi33
Luigi33
  • 79 posts
Posted 12 January 2016 - 08:40 PM
The car wasnt running very nicely when I got it, so a trip to performance autoworks confirmed 172 bhp at the flywheel:
#3 Luigi33
Luigi33
  • 79 posts
Posted 12 January 2016 - 08:43 PM
I decided to have a few alterations to the car, some planned, some not!
Firstly the timing chain was worn (common on older K20's). So this had to be replaced with a genuine Honda item. A new clockwork motion baffled sump, Kaaz 1.5 plated LSD, an ACT clutch and attention to the CV joints:
#4 Luigi33
Luigi33
  • 79 posts
Posted 12 January 2016 - 08:52 PM
Then off to brands for a dust off:
The 175 Yokohama A539 are ok for the road but not nice on the track and clearly not enough grip to cope with, so this needs to be sorted soon:
Edited by Luigi33, 12 January 2016 - 08:59 PM.
#5 Luigi33
Luigi33
  • 79 posts
Posted 12 January 2016 - 08:54 PM
The car was awful, the steering was all over the place, the car was cutting out after most corners and it weighed more than I thought care of the dynamat fetish the previous owner had:
745kg!!!
#6 Luigi33
Luigi33
  • 79 posts
Posted 12 January 2016 - 08:55 PM
A trip to Tracktive for a remap on the Hydra ECU:
Now running 179bhp at the wheels which is a step in the right direction:
#7 Luigi33
Luigi33
  • 79 posts
Posted 12 January 2016 - 08:58 PM
Current status is car is in a car workshop having the suspension and brakes looked at while we wait for the 13 x 9J minilite wheels to be manufactured. More details to follow when update happens.....
#8 jimmorris3
jimmorris3
  • 64 posts
  • Local Club: sham minis
Posted 13 January 2016 - 06:04 PM
alrite mate, just a heads up , if your going that wide , what tyres are you going to use, everything on the market is quite a lot taller and arches might need redoing
#9 Luigi33
Luigi33
  • 79 posts
Posted 13 January 2016 - 08:41 PM
I have been going through this dilemma today. I have called arc-angels, carbonweeve and absmotorsport and no one offers an arch to accommodate the 215/55/13 Avon ZZS tyre that is planned for the rear.
1 option is to modify the current arch which is not really the way I want to go:
This would mean cutting the arch, widening with more fibreglass but would lose the pressed carbon weave look.
Any other suggestions welcome....
Edited by Luigi33, 13 January 2016 - 08:42 PM.
#10 andream88
andream88
  • 169 posts
Posted 13 January 2016 - 09:32 PM
Zcars used to make some wider arches for the 9" wheels.
Call Chris and ask!
#11 Bennyboybusa
Bennyboybusa
  • 34 posts
Posted 13 January 2016 - 10:31 PM
Arch angels do 9" rear arches
#12 jimmorris3
jimmorris3
  • 64 posts
Posted 14 January 2016 - 06:18 PM
Im not on about the width of the wheel mate its the extra 30mm + in tyre height , cutting the steel quarters is more than likely .
I went from a 195 45 13 to a 195 50 13 and had no end of problems .
The tyres you've got on there are 504 in height ( i think )
the avon 215 is 559
just a heads up because i have had a lot of issues with it
#13 Luigi33
Luigi33
  • 79 posts
Posted 16 January 2016 - 02:37 PM
Ok so the tyres turned up today and for reference they are the Avon ZZS 185/55/13 and 215/55/13 set up which looks staggered and a big radius...
#14 jimmorris3
jimmorris3
  • 64 posts
Posted 16 January 2016 - 04:42 PM
Sit on of your wheels next to them, think you'll be surprised
#15 Luigi33
Luigi33
  • 79 posts
Posted 17 January 2016 - 01:37 PM
Will do but the car is in a workshop and tyres at home. Just looking at the difference between the front and rear in terms of size its easy to see how there might be some teething issues
