Saxo Engine Install, My Progress So Far.
#46
Posted 20 February 2016 - 08:35 AM
#47
Posted 20 February 2016 - 11:07 PM
For my rad pipes I went to the local parts place and went through the OE pipes they had to find some that when chopped and joined would work...
Edited by fuzzy-hair-man, 21 February 2016 - 12:01 AM.
#48
Posted 21 February 2016 - 10:26 PM
#49
Posted 21 February 2016 - 10:35 PM
If you're local to Andover Hampshire I have access to a lathe.
Cheers for that mate have you done drive shafts before.
#50
Posted 22 February 2016 - 11:54 AM
No I haven't but I've heard you normally cut them to a point so there is a large surface to weld them back together.Cheers for that mate have you done drive shafts before.If you're local to Andover Hampshire I have access to a lathe.
#51
Posted 02 April 2016 - 02:59 PM
Painted rear subframe in black enamel, may flat and give a few more coats.
A few brackets
Edited by cookie4343, 02 April 2016 - 03:03 PM.
#52
Posted 03 April 2016 - 06:49 PM
#53
Posted 30 June 2016 - 08:09 PM
A few pics but nothing exciting.
Steering rack serviced and new boots and lock nuts fitted.
Subframe as it sits, been brush painting for convenience just in case I need to do more if I've missed anything.
#54
Posted 05 July 2016 - 07:24 PM
#55
Posted 13 July 2016 - 09:14 AM
My deadline is Christmas otherwise I might sell up and move on in the car scene away from mini's.
#56
Posted 13 July 2016 - 10:16 AM
#57
Posted 14 July 2016 - 02:43 PM
#58
Posted 16 July 2016 - 06:28 PM
Refitted subframe and steering rack.
Engine and box went back in.
Had another go at the gear linkages, decided to use a rover k series selector and modified it all to work.
I have all gears but the throw is quite short so still abit more work to get perfect.
#59
Posted 29 November 2016 - 10:46 PM
