Dreaded Head Gasket.
40 replies to this topic
#31 OllieH
OllieH
  • 37 posts
Posted 26 January 2016 - 12:54 PM
Unleaded head ordered, aiming to sort it all Friday. Cheers for everybody's input.
#32 jaydee
jaydee
  • 8,565 posts
Posted 26 January 2016 - 01:52 PM
I saw 0 psi once. Headgasket  had a massive blow between two cylinders.
#33 OllieH
OllieH
  • 37 posts
Posted 31 January 2016 - 02:18 PM
Gasket replaced and running fine. Small mix up with the cylinder head (I was sent a 1275 not a 998) Intending to swap heads as soon as possible after the correct one arrives!
#34 mk1leg
mk1leg
  • 9,343 posts
Posted 31 January 2016 - 03:31 PM
use 5amp fuse wire 50mm long and use a smear of hylomar blue on block face in between bores then place fuse wire on this then new head gasket then the head which the face must be cleaned with thinners then torgue it up
#35 OllieH
OllieH
  • 37 posts
Posted 31 January 2016 - 07:10 PM
Well. Clearly I spoke to soon.
#36 floormanager
floormanager
  • 791 posts
  • Local Club: Mini Club Sussex
Posted 31 January 2016 - 07:14 PM
Really? how does the fuse wire help?
#37 Gr4h4m
Gr4h4m
  • 1,802 posts
  • Local Club: Club less.....
Posted 31 January 2016 - 08:30 PM
Are you saying you've just put the 1275 head on a 998?
#38 OllieH
OllieH
  • 37 posts
Posted 31 January 2016 - 10:25 PM
No buddy, I can't even imagine what damage that would cause! I ordered a 998 head, I was sent a 1275, after realising, I contacted the seller and the correct head is due tomorrow I believe and will be swapped with the original as soon as possible. It currently has the original head with a new gasket on.
#39 mk1leg
mk1leg
  • 9,343 posts
Posted 31 January 2016 - 11:13 PM
stops Inter bore blow through see Janspeed video 58sec in
#40 floormanager
floormanager
  • 791 posts
Posted 01 February 2016 - 07:31 PM
Thanks for the link to the video - I've learnt something today.  Janspeed look like they are using some form of glue to hold the wire in place.  Truly amazed at usimg fuse wire!
#41 jaydee
jaydee
  • 8,565 posts
Posted 02 February 2016 - 09:38 AM
Similar has been done in the past to isolate water ways on blocks where the deck surface wasnt at the best conditions, but using sawing wire instead of fuse wire.
