Aesthetics For My Mini
Posted 07 February 2016 - 07:49 AM
Another thing would be to put bonnet stripes on the car to make it look more mini and maybe even 2 rally headlights in the front and change the grille to a standard one as I don't like the new one at all. Would you guys also recommend installing a hed light set or would that ruin the mini look?
I know this may be a pointless topic but would just like your thoughts on what I could do to my mini on the outside.
Posted 07 February 2016 - 08:17 AM
a photo would be nice...
and if you post on the digital mini section, perhaps some nice person might be able to photoshop some of your ideas..?
Posted 07 February 2016 - 10:22 AM
Sorry thought I had attached a photo. Here's one. image.jpeg 76.94K 41 downloads image.jpeg 76.94K 41 downloads
Posted 07 February 2016 - 10:55 AM
they might be nice matched to the body colour
Posted 07 February 2016 - 11:32 AM
What size are they? as i have a set of silver ones that i don't really like the look of, so was thinking of spring them black, could look at a trade if you're interested?
PM me if you are?!
C
Posted 07 February 2016 - 02:30 PM
I'm not a fan of black rims either, but unless they're in really bad condition it would be cheaper and a lot less hassle to buy another set and then sell these on as opposed to repainting them. Wavy grilles aren't to everyone's taste and in my opinion tend to look better as the mk1 version with the earlier moustache surround and on cars with other retro styled mods such as mk1 indicators and 10" rims. Personally I'd fit a standard Cooper straight slatted version instead. Unless it's what you specifically want, then I wouldn't go for the whole Rover Cooper bonnet stripes and fog lamps set up personally, as you'll just make your car look like everyone else's, If it were mine, then I'd swap to Silver rims and a Cooper grille and then also swap the indicator & side repeater lenses for the clear or smoked version and then go from there. The standard Orange items tend to look dated and in my opinion only work on 80's period styled models.
I'm not sure what the "hed light set" you're referring to is though, can you explain?
Posted 07 February 2016 - 03:14 PM
**Moved to Styling section**
Ideally I would like to take some of the ideas from this mini like the grille and plain lights. The HED lights are pretty much led lights and are really bright. image.jpeg 147.22K 10 downloads image.jpeg 147.22K 10 downloads image.jpeg 147.22K 10 downloads image.jpeg 147.22K 10 downloads image.jpeg 147.22K 10 downloads image.jpeg 147.22K 10 downloads image.jpeg 147.22K 10 downloads image.jpeg 147.22K 10 downloads
Posted 07 February 2016 - 03:18 PM
PM me if you are?!
C
Will try and find out the size as I'm not really a fan of the black but would really like a silver set. They are currently on yokahomas on the front and back. I'm in Surrey pretty much south of London, where are you?
Posted 07 February 2016 - 04:21 PM
Posted 07 February 2016 - 04:42 PM
PM me if you are?!
C
I'm in either bristol or Hampshire, so depending on size/ what you think of mine we might be able to sort something out?!?
Posted 09 February 2016 - 01:29 PM
I think your car looks cool as it is, youre almost saying shall i turn it into a cooper lookalike. I wouldnt bother with adding spot lamps and I dont think bonnet stripes would suit it, but then i'm into less is more. I'm not a fan of the wavy grille, maybe a cooper grille?
Posted 09 February 2016 - 09:45 PM
Posted 13 February 2016 - 02:01 AM
YOUR MINI, YOUR CHOICE!
When looking for inspiration I just googled classic mini, but it looks like you have your mind set on what you want and luckily for you it's easily done. Good luck and keep us posted with pics.
You can pick up an internal release kit easily, I have used this one in the past:
http://www.ebay.co.u...iFKnzo2Gkw6bLVA
Easy to install but I must admit I did feel a little ripped off. Not a lot for 30quid, supply and demand I suppose.
Posted 13 February 2016 - 11:30 AM
Posted 14 February 2016 - 01:46 AM
Thanks will keep people posted, does the kit come with instruction, think I will install one as anyone could get in the bonnet and is quit e a cool extra
Does come with instructions (very easy) basically you replace the bonnet catch, the new one has the bonnet release cable attached, then route the cable alongside the o/s inner wing, through a grommet on the fire wall, then just attach the bracket that comes with it to the bottom dash rail but the end on the cable and VOILA! you will need to play around moving the new catch about to make sure it lines up right, but easy.
