Does Anyone Know Anything About Hif44's?
Posted 07 February 2016 - 06:07 PM
Posted 07 February 2016 - 06:13 PM
Posted 07 February 2016 - 06:23 PM
go for it
Posted 07 February 2016 - 07:15 PM
Off topic, sorry in advance.
The end of a joke always pops in to my head when ever I hear / read the words 'Does anyone know anything about,,,,,,'
A guy parachuting out of a plane, pulls for the Main Chute and it fails to Open, he's only just done his training and this is his first solo Jump. A little bit of panic set in and then he goes for the Reserve. Same happens again - nothing.
On his way down, he passes another guy going up;-
"Hey mate, know anything about parachutes?"
Nope - you know anything about Gas BBQs?"
OK, so back on topic
Steve on this forum I'm sure know about parachutes.
What do you need to know about Gas BBQs?
Edited by Moke Spider, 07 February 2016 - 07:16 PM.
Posted 07 February 2016 - 08:22 PM
Edited by HUBBA.HUBBA, 07 February 2016 - 08:22 PM.
Posted 07 February 2016 - 08:25 PM
venturi still applies
It can go from Vacuum to Pressure on a boosted application.
There is a special HIF used in Boosted applications, though it's quite feasible and easy to modify a stock one, mainly for the problem that you've highlighted.
speed of air over fuel inlet
Posted 07 February 2016 - 08:29 PM
Correct, negative or positive pressure passing over the bridge in the carb creates the venturi effect which draws fuel through the jet then in turn is metered by the needle.
Posted 07 February 2016 - 08:40 PM
Yes, but on the over-run, you'd be venting quite a bit of fuel out through the Float Bowl vent.
Posted 07 February 2016 - 08:44 PM
Ahh that explains it. I thought the venturi effect only worked in the carb with a negative pressure venturi with neg pressure drawing the fuel out.Correct, negative or positive pressure passing over the bridge in the carb creates the venturi effect which draws fuel through the jet then in turn is metered by the needle.venturi still applies
It now makes sense to me saying its the speed of the air flow.
Thanks chaps
One other thing, anybody know how far up or down the piston/needle is likely to be at cruise speed.
Posted 07 February 2016 - 08:50 PM
Thanks chaps
What speed do you call "cruise" ?
Posted 07 February 2016 - 08:56 PM
its only going to be approximate but would expect to be about 3/4 it really depends on needle profile, compression ect
Posted 07 February 2016 - 09:10 PM
spindle seals go on the wrong way and it's got the dashpot seal.
