Hi guys
I have just finished rebuilding my 1380 engine just gone to start it and it wont fire up wont's to but nothing.
I have just run a compression test and NO:4 cylinder is only pushing 3 psi.
New piston rings were fitted and all off set to each other not sure but could it be the rings are not sealing correctly was wondering if a drop of oil in the cylinder would do the trick? then turn it over to see if it makes a better seal or opens the ring up if it is stuck?
Any help would be great full as i don't wont to strip it down again.
