Am adding pre-Verto lightened steel flywheel + clutch + pressure plate to an A+ Metro motor taken out to 1380, and have to convert the Wok back a decade or so.
I'm not clear as to exactly what parts are required, despite my best intentions.
1. Can someone confirm that the A+ Metro Wok can be kept, or do I have to find a pre-Verto one ?
2. Which of the release-mechanism arm/sliding-slug parts do I need to source ?
3. I am assuming that I need and old-type slave cylinder, but where does it fasten - presumably nothing to do with the Verto-type adapter support plate ?
4. Does it matter if there is quite a lot of slop in the Wok's bore where the slug, er, slides ? Do these ever need re-sleeving ?
DSC07109.JPG 87.98K
18 downloads
5. Does the pre-Verto use up a lot more head-room - see picture, my battery occupies quite a lot of that area ..................
Many thanks for all/any help/advice.
Rory
