Guys
I'm running a 03 R1 engine in my mini project.
Due to the obvious psychics of cornering etc I have fitted a sump oil baffle plate and removed the oil level light in the process. Now to combat the oil level light removal I have plumbed in an oil pressure gauge into the oil cooler.
My question is what pressures should I be getting?
Has anyone else done this??
I'm having it sit idling and getting 30psi then on revs it's going up past 150psi!?!?(might be a faulty reading)
I'm sure I read that R1 pressure relief was 70 ish PSI
What should the pressures be? Thanks
R1 Oil Pressure
blunder
, Mar 19 2016 04:43 AM
1 reply to this topic
