I have for sale 2x Metro Turbo Plenum chambers.
I originally bought these for research as I'm currently in the process of remanufacturing a similar version for my Podifold supercharger system.
One has been grit blasted and can be used as is or painted. The brass fitting that connects to the fuel pressure regulator had been snapped off before I got it so I've drilled and tapped it out and replaced it with a stainless steel hose tail.
The other one is standard.
Both are complete with the poppet valve and restrictor ring.
I'm after £75 each posted for them.
This topic is locked
