On a slight tangent. Just a note of some of the tools I regularly use for the work on this project.
My GYS Smartmig 162 (And Clarke light-reactive helmet facing the wrong way). Gas is 5/95 CO2.Argon:
New right angled Clarke die grinder with a 50mm Roloc disc holder (and disc) mounted:
My Dremel with a flexi hose and ez-clic grinder mounted (from grinding out the shear bolts on the pedal box):
A drawer full of clamps, including my copper backed plug weld clamp - need to up the power on the welder when using that.
Angle grinder with flac disc mounted:
Another angle grinder with a (finer) wire brush mounted:
And the essential PPE. Nitrile gloves, heavier gloves and a grinding mask.
Dust mask, various eye protection and welding gloves. Tend to only wear the left welding glove. Tut tut.
My compressor. 14cfm. Tank is only 50l, so an upgrade may be required at some point:
Cheap-ass straight die grinder with a (knackered) wire brush mounted:
And a mix of budget and quality discs for the angle grinders:
Edited by wombatjock, 16 September 2018 - 04:18 PM.
