1962 Tax exempt classic mini K20 RWD vtec type R LSD
300 bhp per tonne/0-60 in 3.8 seconds/Lotus elise alignment geo
This is a serious performance car that has been professionally built costing £30k.
Car is registered as 1962 austin mini which is now tax exempt and able to run on black number plates. It has a full bare metal respray in 2010 in Honda nighthawk black.
The car is road legal and current MOT is valid until October 2016. The V5 is present and HPI clear.
Please dont confuse this with the average builds you see around, no corner has been cut and as well as turning heads, this car has the performance, handling, grip and stopping power that is essential to being able to use it properly.
The car is in excellent condition and turns heads and constantly gets attention questions from public when used. The car can be used on the road and has been set up to be a weapon on track and could be used for sprints/hillclimb although it has only been used for occasional road use and 1 track day
I will start with the spec:
Chassis/body
Front
Zcars conversion in 2010 with blue frame/cage and includes front and rear subframe
Fibreglass front wings/bonnet with vent and fuel filler cap
Lightened to 730kg
Steering
Minispeed 2.2 short ratio steering rack (standard 2.7 rack included in sale)
Steering column lowered 1 inch for better position and can easily be adjusted
Mini 3 spoke steering wheel
Mini speed uprated strengthened drive hub flange
New front and rear wheel bearings packed with race grease
Interior
Carbon fibre dash
Dash 2 console system featuring shift indicator/speed/rpm/water temp/fuel pressure/oil pressure/odoometer
Original door cars/stainless handles/functioning windows/sunroof/rear windows
Glass windows throughout
Doors can be locked as per factory spec and immobiliser for security
Mambo wide bucket seats
4 point harnesses
Full dynamat top and bottom
Aluminium firewall around engine and covered in carpet can easily be removed to access engine
Original carpet interior fully restored
Indicators/lights/hazard all function to retain road legal state
Engine/Drive train
K20A2 Honda Civic Type R engine from 2003 car covered 83000
Honda 6 speed drive train
In 2015 Performance autoworks carried out the following upgrades and car has covered less than 500 miles since:
New genuine Honda timing chain
Kaaz 1.5 plated LSD with new diff bearings
Kaiten lightened flywheel
CV boots replaced and greased
ACT stage 1 clutch
Clockwork motion baffled sump
Stainless steel exhaust system with 2 silencer for 93db
Hydra standalone ECU remapped by Tracktive in 2015
AEM fuel rail
1.5L swirl pot, facet fuel pump, new 8mm fuel lines throughout
Fuel pressure regulator
Brakes
Front wilwood Dynalite 4 pot calipers,brand new Zcars 258mm floating rotors, brand new Zcars aluminium bells, goodridge hoses, Wilwood race pads (spare x2 floating rotors included)
Rear wilwood Dynalite 4 pot calipers, 257mm vauxhall adam vented rotors, goodridge hoses, Wilwood race pads
Brake fluid and pads were only replaced less than 500 miles ago
Internally adjusted front/rear AP bias valve
Suspension
Front inboard suspension with protech height/damping/rebound adjustment and 400lb springs
Adjustable for camber/toe/caster
Rear protech height/damping/rebound adjustment and 400lb springs adjustable toe, camber
Full alignment carried out using Lotus Elise S1 settings
Wheels/Tyres
Front 13x7 minilites with brand new Avon ZZS dry/wet tyres
Rear 13x9 minilites with brand new Avon ZZS dry/wet tyres
Spare 13x7 minilites x 2 with Yokohoma A539
Spare x2 Yokohoma A539
Price £15995 (price adjusted realistically to sell)
Location Farnham Surrey
Pictures to follow
Edited by Luigi33, 29 April 2016 - 04:04 PM.
