Hi guys, just trying to figure out a price on a couple of engines I'm going to be putting up for sale soon.
1st engine:
Covered 1000 miles since full rebuild.
New gaskets, oil pump, all bearings etc
1293 A+
21253 pistons
Arp rod bolts
Centre main strap
Pre-verto, standard flywheel
Fully balanced
Sw5-07 cam
Alloy vernier timing gear
GT ratio gearbox
3.1 final drive
Centre oil pick up
Head is 12g940
33/29 valves
Leaded
28cc chambers
180lb double valve springs
Standard ports
No ancillaries or inlet+exhaust manifolds.
2nd engine:
1275, unknown condition, came with a kit car I bought with 22000 miles on the clock, not been on the road since 1991. Was told it was a runner but never had it running myself.
Head has some stuff stamped on it so presume it's had some stuff done to it. Gearbox will need some attention as the punch got stuck when removing the roll pin for the gear linkage so I chopped it off with the grinder :/
Also have a 28/36 webber carb with inlet manifold from the above engine.
James
Edited by morley, 05 May 2016 - 05:08 PM.
