Tuning Advice - Reworked Mk1 998 Cooper
engine electrical
11 replies to this topic
#1 guywilko
guywilko
  • 46 posts
Posted 26 May 2016 - 03:52 PM
Hi Folks.
I have rebuilt my Mk1 cooper engine and it is running. I will be taking it to a RR for a dyno tune, but would like some advice on  a pair of needles to get me started and (which CSI) dizzy advance curves would work best please.
The spec is;
Original A series block and crank
998 +20 Flat top to deck
Kent 266
Duplex vernier chain
Small bore roller rockers 1.25
Twin HS2 with knife edge spindles etc
K+N Pancake air filters
1.25 low profile stub stax
12G295 ported and enlarged inlet valves
CR 10.25
Lightened road flywheel
Maniflow small bore LCB
Single Back box 1.5" exhaust
PCV retained
I will be fitting a new programmable CSI 25D dizzy + vacuum . Advance curves are here    http://www.csi-ignit...es_850-1275.pdf
Cheers Guy
#2 MiniMat42
MiniMat42
  • 31 posts
Posted 26 May 2016 - 06:10 PM
Guy,
Do you have a copy of Vizard's bible.....
Failing that if the engine is running a good RR company will either replace of modify the needles on site.
and also adjust the dizzy advacne
#3 dyshipfakta
dyshipfakta
  • 1,696 posts
Posted 26 May 2016 - 06:41 PM
He needs to get there though...
#4 guywilko
guywilko
  • 46 posts
Posted 26 May 2016 - 11:03 PM
Yep, I'm wondering how much advance will be required at different RPM.
I will scrounge around in the attic for Vizard's * yellow bible* to help needle selection.
Ps it'll be drinking super unleaded
Thanks for your help chaps!!
G
#5 madaboutcherry
madaboutcherry
  • 539 posts
  • Local Club: no
Posted 27 May 2016 - 11:03 AM
try m needles to start, if they're a bit rich try gy. they should get you there.
#6 carbon
carbon
  • 2,590 posts
Posted 27 May 2016 - 04:59 PM
M needles are a good starting point for this spec, use with the blue springs
#7 madaboutcherry
madaboutcherry
  • 539 posts
  • Local Club: no
Posted 27 May 2016 - 05:05 PM
I would have thought red springs would be better.
#8 carbon
carbon
  • 2,590 posts
Posted 27 May 2016 - 05:08 PM
M needles and red springs would likely be too rich for this spec.
Blue springs run weaker than red.
#9 guywilko
guywilko
  • 46 posts
Posted 01 June 2016 - 01:02 PM
My carbs are newish - swinging needle type. I can only find  M as a fixed needle. Will this fit/work?
Anyone any opinions on the preferred dizzy curve ?
Thx! Guy
#10 Minigman
Minigman
  • 779 posts
Posted 04 November 2016 - 08:27 PM
Just came across this randomly.
How did the RR go?
Very tempted to build identical spec.
#11 tb205gti
tb205gti
  • 186 posts
Posted 05 November 2016 - 08:39 PM
How did the RR go?
Same here..
#12 guywilko
guywilko
  • 46 posts
Posted 06 February 2018 - 11:26 AM
Minigman and 205GTi
I'm getting my arse in gear and sorting out a RR session for the mini this spring, (got distracted by a 911 last year!)
G
Also tagged with one or more of these keywords: engine, electrical
