Advice Please
12 replies to this topic
#1 mikal
mikal
  • 240 posts
Posted 27 May 2016 - 08:26 AM
I have a newly restored '67 Mk 1 Deluxe (In name only, all souped up, 1293, Weber, cam, LCB etc). I've just removed the engine because 3rd gear synchro was a bit dodgy (new close ratio 4 synchro box). That's getting fixed under warranty, dodgy baulk ring apparently. Depressing!
Regardless, the new paintwork (2K) behind the extractors on the bulkhead is bubbling after only 5000km. Highly depressing!
What are your comments and suggestions please. Is it odd the paint is failing like this so soon? Should the 2k paint ought to cope with these temperatures. It is a street car.
My current thoughts are to clean it up and repaint with spray can Ferrari red but will this work any better is these circumstances? I don't have photo's but you can imagine bubbling paint I guess. It was about 3 weeks after painting the car the engine was first run.
Appreciate your advice.
Mikal
Photo added...
And a few of the car... (and my Vespa, '62 model)
Edited by mikal, 28 May 2016 - 03:59 AM.
#2 dyshipfakta
dyshipfakta
  • 1,696 posts
Posted 27 May 2016 - 08:41 AM
Repaint it with very high temperature paint if you aren't going to see it. Atleast then you know it's not going to happen again due to heat.
#3 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 15,900 posts
  • Name: Neil
Posted 27 May 2016 - 08:42 AM
It could be heat affecting the new paint possibly. Maybe worth fully removing the affected paint back to bare metal, thoroughly clean and degrease then etch prime, prime and paint.
#4 Daz1968
Daz1968
  • 2,058 posts
Posted 27 May 2016 - 08:31 PM
Think the works cars had a heatproof pad on bulkhead, I have never had the issue described though so maybe exhaust a little close, you could always heat wrap the manifold down to the y piece to help as well.
#5 mikal
mikal
  • 240 posts
Posted 27 May 2016 - 08:35 PM
Thanks for the replies guys. But should 2k paint fail like that. .. I'm confused about that....
#6 sonikk4
sonikk4
  • 15,900 posts
  • Name: Neil
Posted 27 May 2016 - 09:19 PM
IT should not but there may be other factors at work here, paint not fully cured, contaminants on the bulkhead etc etc.
#7 mikal
mikal
  • 240 posts
Posted 28 May 2016 - 04:00 AM
Photo's added, firewall photo not great but you get the idea..
Mikal
#8 sonikk4
sonikk4
  • 15,900 posts
  • Name: Neil
Posted 28 May 2016 - 06:41 AM
It does look burnt but also signs of something like oil possibly. As I said strip it back completely to bare metal etch prime, prime and then topcoat making sure each stage the paint has flashed off properly.
#9 midridge2
midridge2
  • 1,794 posts
Posted 28 May 2016 - 08:13 AM
It looks like water/brake fluid etc  has come through, take it back to bare metal, etch, prime then bar coat it.
#10 mikal
mikal
  • 240 posts
Posted 28 May 2016 - 12:02 PM
Definitely no brake fluid involved. Taking it back to bare metal sounds drastic if not depressing. I'll rub it back and paint it with high temp paint, hopefully red if I can find it. Thanks for your comments...
#11 sonikk4
sonikk4
  • 15,900 posts
  • Name: Neil
Posted 28 May 2016 - 12:14 PM
This can be done quite quickly, grinder with a wire brush on it will take that off very quickly. Better to remove it completely rather than risking it contaminating the new paint.
#12 Cooperman
  • 23,039 posts
Posted 28 May 2016 - 12:25 PM
The original 'works' cars did, indeed, have a (whisper it) rectangular asbestos plate bolted onto the bulkhead just below the cross-member. I also have one on my 'S'. Paint bubbling/burning is always a problem in that area when an LCB is fitted.
#13 tiger99
tiger99
  • 8,584 posts
Posted 06 June 2016 - 01:14 PM
In that case, there are various modern asbestos - free insulating materials that could be fitted. A lot of excess heat gets into Minis of all sorts, and indeed cars of all sorts, via the exhaust and there is an entire range of stuff which can help, including exhaust coatings and flexible insulation for the floor and bulkhead. The kit car suppliers have suitable materials.
I would suggest a ceramic coating on the LCB first.
