Rear Subframe Repair?...
rust repair
16 replies to this topic
#16 tiger99
tiger99
  • 8,584 posts
Posted 02 June 2016 - 08:51 AM
At one time you could get a repair panel for that area. If you still can, it would speed up the repair by being already shaped.
Just make sure that it has a full seam weld at each end and intermittent welds to the vertical webs. There is very high Peak tension in the subframe side members, possibly 2 tonnes at peak spring compression on bump. That is something that is within the scope of a careful weld repair. You should be able to do better than the skimped spot welds on certain non-genuine subframe!
#17 Pepys
Pepys
  • 72 posts
  • Local Club: None
Posted 02 June 2016 - 03:31 PM
Thanks again for the information everyone. I'll make an another inspection of the frame and make a plan. Gotta weld up the holes in the boot too and decide what to do with the cavities behind the valance closing plate. All good fun.  :-)
Also tagged with one or more of these keywords: rust repair
