any suggestions?
Tips For Putting Front / Rear Windows Back In
Posted 30 May 2016 - 08:42 PM
Posted 30 May 2016 - 08:46 PM
Posted 30 May 2016 - 08:47 PM
any suggestions?
a bowl of soapy water and some neat washing up liquid for the very tight bits
Posted 30 May 2016 - 08:58 PM
A lot of people are against the use of silicone and washing up liquid near paint.
Silicone because its a ******* to respray anything thats been contaminated.
Washing up liquid because it contains a lot of salt.
Slightly better options are car wax champoo and "bedroom " lube.
Posted 30 May 2016 - 09:06 PM
Rubber in.
Screen in the channel at the bottom.
Lever the rubber over the sides and top of the screen
I have used normal multi lubricant spray. spray this into the channel where the filler strip goes.
Start at the top, insert the tool (you really need the tool)
Feed the strip through the tool and then run the too around the screen.
I have done it this way 4 times now, I reckon i can get a screen in under 10 minutes.
Posted 30 May 2016 - 09:39 PM
If you can leave the rubbers in the sun for 10mins before you start as if makes the rubber easier to work with also a small plastic spatula type tool will help loads.
Posted 30 May 2016 - 09:47 PM
put rubber surround in a bucket of hot water for 15 mins
makes it more flexable
Posted 31 May 2016 - 04:32 AM
any suggestions?
I actually find it's just about one of the dead easiest jobs to do.
In fact, it's so easy, I usually do it with one finger.
I call my glass man and he does it.
See, easy
Posted 01 June 2016 - 03:11 PM
Posted 01 June 2016 - 04:00 PM
KY jelly is the lube to use!
Posted 01 June 2016 - 07:09 PM
I was going to ask which was the 'bedroom' lube of choice.
Which is the best tool to fit the chrome filler strip.
There are some quite cheap ones about.
Posted 01 June 2016 - 07:30 PM
You know your bedroom lube well 😂 And yes it's the one I use(on the mini) not myself 😁
Regarding the tool to use.. Going from what available on the mini spares website(can't link on my phone) I bought the cheaper one(without the roller) and it did the job, I have found however that you need to be careful with it as you can catch the filler strip and mark it quite easily! Also after doing numerous Windows with it(maybe 4 minis) back and front it's twisting and is now making it difficult to use! If anyone has a review on the more expensive one with the roller on id be very interested to hear it, as I think I'll need to purchase one soon!
Posted 01 June 2016 - 07:49 PM
Like everybody else says. Rubber in 1st, glass in the bottom and work around with a spoon or anything else within hands reach.
Stay away from rubbers that are not joined, beware rubbers for toughened and laminated glass are different and after fitting the chrome trim leave the excess overnight if possible as it will shrink back. when you trim to size add a couple of mm to give it some extra leeway.
I use a standard trim tool without the roller and use the back of my index finger to keep a small amount of pressure on the trim,
I smear a small amount of tyre soap in the groove and job done in about 3 mins.
I`ve done quite a few fire engines, boats, Landrovers etc and having black infills mean they don`t come back every 18 months because the chrome trim has turned yellow!!
Why is everything so junk these days
Posted 01 June 2016 - 08:33 PM
I use wd40 and not shy with it<
Im not sure why you guys have so much bum lube!!!!!!!!
i always just in case mask up the scuttle incase i drop it and scratch the paint
be patient
rubber in first
drivers side bottom first
slide it along and work round with a plastic tool thin and blunt
I find the original rubbers are better than new as long as there not fu ked
Posted 01 June 2016 - 09:07 PM
Might try this rubber first lark.
