Scot
I do not doubt your knowledge and experience
but mine was different
the easiest ways to see how you are running rich are looking at the crud build up on your tail pipe
and pulling the plugs
since running unplugged my plugs are perfect - tan brown no oilyness and no sootiness
but as you say in the long run it certainly could foul up the also expensive cat system
plus my mpg is brilliant now - perfect starting and perfect idle
sometimes for me machines are a mystery
also to the OP I would, if it was me, just replace your vacuum hoses with the continuous silicone hose available online - for less than a few pounds you buy a few meters worth cut it to length, avoid any sharp bends and there are no joins and you are good for a long time - the important thing is to get tube that is not too thin as you don't want it to suck itself out of shape, so check the id and od - all the best
