Lambda Sensor? Running Very Rich
68 replies to this topic
#61 ryomini
ryomini
  • 583 posts
Posted 26 June 2016 - 08:19 AM
Yes FS I agree with you that doing it properly is the better way to do things
I should like to grab one of those diagnostic tools myself as I seem to be holding on to
my Spi minis and enjoy them very much
#62 tmsmini
tmsmini
  • 709 posts
  • Local Club: MOASF
Posted 26 June 2016 - 04:11 PM
I have been away for a week and I apologize if this was addressed earlier...it appears that there is some "creative" rewiring in the engine bay.
I would try to make sure this is cleaned up. I have seen cars where portions of the loom were not secured where they are supposed to be and abrasion has exposed wiring which can lead to additional corrosion. Are your grounds good and without corrosion?
#63 WoodlandsMini
WoodlandsMini
  • 208 posts
  • Local Club: AutoJungle
Posted 26 June 2016 - 07:40 PM
They appear to be, tried removing and re-adding, I have taken a slightly extreme route...
I have another injector which I can now swap and try that out... but it also came with all of the sensors... and as a just in case I also got a whole wiring loom since this was pretty bad anyway :) will give that a try
#64 ryomini
ryomini
  • 583 posts
Posted 27 June 2016 - 03:55 AM
You haven't thrown the towel in yet
but this has been quite a pain
interesting to see what the real issue / issues are
#65 WoodlandsMini
WoodlandsMini
  • 208 posts
Posted 27 June 2016 - 12:21 PM
Very frustrating! I will try the injector tonight :)
Fingers crossed!
#66 WoodlandsMini
WoodlandsMini
  • 208 posts
Posted 27 June 2016 - 07:24 PM
We have life!
Bad news is we also have a weird lambda reading... 1.8v and its doesnt seem to be fluctuation much!
I'm guessing this could be a manifold leak? Anything else worth checking?
#67 WoodlandsMini
WoodlandsMini
  • 208 posts
Posted 27 June 2016 - 07:54 PM
Readings from ACR4
#68 ryomini
ryomini
  • 583 posts
Posted 28 June 2016 - 01:31 AM
Not wanting to throw you off in a wrong direction as I am far from knowledgeable
how long ago was your fuel filter changed - the tin can looking thing under the boot left hand side
and again
what sort of condition is the bottom of your petrol tank in - could be full of crud
also I assume you are using high octane petrol (I don't know what that is in England)
there are so many components in a system and one or many could be found fawlty ;)
#69 WoodlandsMini
WoodlandsMini
  • 208 posts
Posted 02 July 2016 - 06:51 PM
Passed, but only just!
It seemed to be a combination of things, lambda or CTS (changed at same time) made it run better but not right.
I have a new cat for the car, which I will fit later this year whilst checking exhaust (slight leak) on MOT
Thanks again for all those that suggested different things
