Anyone Used Enviro-Strip?
#16
Posted 13 June 2016 - 08:38 PM
I am very pleased with this result and strongly recommend the company.
I attach a couple of pictures.
image.jpeg 119.86K 46 downloads
image.jpeg 116.8K 39 downloads
#17
Posted 18 June 2016 - 07:11 AM
That looks amazing. I suppose you've a number of months to get the welding repairs done before too much surface rust builds up.
Then you go back for a re-dip and 2k primer right?
What exactly is 2k primer? Is it 2-pack paint? I thought that wasn't used any more?
Adam
#18
Posted 18 June 2016 - 04:51 PM
My shell will go directly from re-dip to the paint shop I am using for both primer and paint, so I don't plan to go through the EnviroStrip primer stage. I assume their reference to 2-pack primer means they use a chemical hardener in their professional shop, but I think you are correct - the use of this is decreasing since the hardener is poisonous during application and does need a professional shop with good extraction.
Given your location, unless you have a lot of welding to do, then I would consider going for the whole four stage process at EnviroStrip and doing the whole job through to primer in one trip.
I hope that this helps
Peter
#19
Posted 19 June 2016 - 08:15 AM
Thanks a million Peter. You've been a great help with your info.
#20
Posted 16 August 2018 - 04:54 PM
I can't print my opinion for in case i'm sued, but not best pleased with how my shell returned. Some on here have had better results. It depends what you are aiming for.
#21
Posted 16 August 2018 - 06:23 PM
However we do like it when people use an existing thread for reporting issues with companies.
Anyway I hope the shell is salvageable!
#22
Posted 16 August 2018 - 07:14 PM
It came back like the previous posts pics minus paint as agreed but had holes drilled in areas not meant to be and unwelcome dents. Where they came from who knows,?
#23
Posted 16 August 2018 - 08:07 PM
Edited by cal844, 16 August 2018 - 08:08 PM.
#24
Posted 19 August 2018 - 12:09 PM
Hi, the car was rebuilt by us 1st time round and so we knew all the filled area's these were new dents and as for the drilled holes no one said that was going to be done. Would not have sent car away if I knew what I know now.
