Looking good! Was it your first time at Blyton? I've never done it in a mini but done it in an mx5 and thought it was a really good circuit!
The only thing I did notice is a quite a bit of movement in your harness like it wasn't tight. If the worst should happen and you have an accident, you might do more harm than good with them not being tight enough
Second time, I went to the MK1 Performance action day this year, but that was just overtaking standard engined minis on the straights and getting traffic in corners haha.
There was only about 12 cars on so really got to push and learn the car a bit better.
Also finally figured out what tyre pressures I should be using as I was about 12psi too high before.
Blyton is great for pushing the car, feels a lot safer than cadwell at least.
I have only tried the outer circuit but I like it lots of hard braking zones and I rqeally liek the fast section out of the double apex corner (think its called BONGA BONGA or something)
Belts felt tight on the day haha
