Hi All,
I have recently undertaken a turbo conversion using a HIF44 carb (with a turbo kit rebuild) however I am having some difficulty getting it to run properly.
I have attached a photo to try and highlight the problem I am having.
Before the turbo was fitted I blocked the pipe that is circled on the carb (silly mistake) shown in the photo which prevented the car to start. After much frustration I realized my error took the blanking pipe off and happy days the engine started and ran like a dream first and every time.
Now the turbo is fitted, I have done much research and everywhere says this must be block to allow the pressure to building to then send back to the fuel reg etc. However, if I block it, the car has the same problem as above and refuses to start. Unblocked, the car starts (happy days again) however as soon as the boost builds up there a lack of fuel and the engine runs lean and stall until rev's/boost drops (not so happy days).
20160619_174428_resized.jpg 35.42K 20 downloads
Any help would be much appreciated.
Regards
