No Timing Mark On Dampener
4 replies to this topic
#1 1955Chevy
1955Chevy
    Starting My Mini Up
  • 3 posts
Posted 14 July 2016 - 09:21 PM
I have a 1992 mini: British Open Classic with a 1275 engine - Manual trans
There is no mark on the pulley for the timing. The timing scale is on the motor. There is a sight hole on the housing end with the Clutch. Its roughly 3/16, not enough to see anything.
The motor cranks a bit slow, I was thinking the timing might be to far advanced.
Any suggestions?
#2 Spider
  • 15,686 posts
Posted 14 July 2016 - 09:30 PM
Slightly O/T but relevant and very important.
It could be that your Harmonic Damper has failed and this can be a warning sign of that.
With the engine off, put the car in top gear and slowly pull it forward by hand while looking at the Damper, there is a notch on the inner side of them, closest to the timing chain cover. If you find it and when at TDC (pull out no. 1 plug and look for the piston, it will give a near enough indication) it doesn't line up with the Timing Marks, then I wouldn't muck about with it, change it for a new one as it will lead to a broken crankshaft.
#3 1955Chevy
1955Chevy
    Starting My Mini Up
  • 3 posts
Posted 14 July 2016 - 11:06 PM
I put it gear and rolled it already, no notch
Anything else?
#4 govig
govig
  • 339 posts
Posted 15 July 2016 - 10:24 AM
Got an MG Metro pulley here if it will fit. Sure it will because it was replaced by a MED alloy for for a Mini.
#5 nicklouse
  • 18,999 posts
Posted 15 July 2016 - 11:12 AM
as Spider said check it is in ok condition.
then mark it up.
