Hi there, got a bit of a strange one here. Got a kind of clicking noise coming from the front drive on the left-hand side when the car is warm and has been driven for a few miles.
If you put your hand on the drive shaft with it jacked up, and rotate the wheel when it's warm you can feel a clunk coming from the driveshaft.
The thing is, both universal joints have been changed, as have the front wheel bearings, the brake discs and pads.
I did notice that the split cone washer has little fractures on the outside, so I have ordered a new one just in case, but could this cause the problem?
The thing is when it's cold it's perfectly fine.
It's coming for its MOT in a few months time and I want to be ahead of any problems like this, that they will pick up.
Any help will be gratefully accepted, yours Aston.
