Wing Question
Posted 28 July 2016 - 03:56 PM
Just taken off a front wheel arch on the mini,which is a group 2 arch, the wing lip has been cut off and on the a panel. While the wing is in good condition there is a lot of flex, I know it would be fiddly but would you weld a new lip back on? The a panels are going to be replaced.
Posted 28 July 2016 - 03:59 PM
There is a strengthening piece that goes between the wing an A-panel
I'm not surprised there's flex, if you're skilled enough to weld a lip back on then go for it
Posted 28 July 2016 - 04:03 PM
Posted 29 July 2016 - 11:32 AM
Posted 29 July 2016 - 08:28 PM
I think you probably want these:
http://www.somerford...products_id=154
Is that basically a lip? Or what I can't tell if so there's a sheet metal place near me that would cut a strip for me.
Posted 30 July 2016 - 10:39 AM
I would suggest making a template of some sort for them to work to. Ask what they need.
The material is 0.9mm mild steel.
Posted 30 July 2016 - 10:44 AM
If there is enough of the wing and A panel left, use a pair of pliers and bend a flange in, then use a hammer and dolly to finish of shaping it.
Posted 30 July 2016 - 07:49 PM
Yes it is basically a lip, so you could most likely get a pair folded and rolled. A bead roller machine would do almosr the entire job, I think, but it might also need a little bit of attention from a shrinker/stretcher to put in the lateral curvature.
Ah so what your saying is it's basically it's kind of an L shape were as I thought it was just a flat piece!!!! Doh on my part!!
Have to look into that not to sure if there is enough metal but it's an idea!
Posted 31 July 2016 - 10:16 PM
Only if you are skilled with hammer and dolly! Maybe you are, it is a skill worth having, but is not that easy to acquire, for me at least. Remember the little stiffner at the joint if you go that way. The L section makes that unnecessary as it bridges the joint, and adds a bit of extra stiffness too, to make up for what is lost when the arch is enlarged.
Actually I have often wondered why the wing and A panel can't be made in one piece, but that is another topic altogether.
Posted 01 August 2016 - 07:38 AM
Then get yourself a piece of round or square bar 1/2" or slightly larger in diameter or width. Cut a slot in the end to a depth of 1/2" so that it mirrors your marked line.
Push the slotted bar into the depth marked on the wing then gently pull the bar up 90 degrees. Carry on the whole way around the wing and A panel.
It's been done by a few members on here and is a very cheap option. Take your time and you may need several passes at a smaller angle to start with rather than trying to go the full 90 degrees in one go.
Posted 01 August 2016 - 07:58 AM
I did the same with a brass rod when I tweaked my front panel
Posted 01 August 2016 - 09:59 AM
Posted 01 August 2016 - 12:11 PM
Edited by tiger99, 01 August 2016 - 12:12 PM.
Posted 01 August 2016 - 01:45 PM
Essential that you go at it very gradually, in order for the bit in the tool to stay bent you'll have to stretch what's between the new and old profile. I'd go for something that doesn't give too much leverage, is a close fit to form a sharp bend and has a square edge that'll be perpendicular to the bend, so you stretch in the right direction - an adjustable spanner.
If there's little spare to form a return like the original, you could have a go at forming a double by bending out and bending back down, to create a small small ridge. Then bend the last few mm of the edge back in to wheel arch, with the aim of creating something similar to the stiffening ridges in a van roof.
