I have had a search and am surprised not to find anything about this fiddly job. I have a 1998 Cooper. I have removed the slave cylinder by only removing the ECU. I just cant get the new one back in, especially hooking the banjo back up as the hose is so short. Can this be done without removing the servo, or has anyone got any tips, ta
Clutch Slave Cylinder Change
Posted 30 July 2016 - 02:51 PM
Posted 30 July 2016 - 03:41 PM
I also removed the top engine steady from the head and bottom steady so it gave a little flex of the engine
Edited by RedRuby, 30 July 2016 - 03:42 PM.
Posted 31 July 2016 - 04:47 PM
Ta, I did look at the breather canister but wasn't sure if i could get that back on once the slave was bolted in.
Posted 01 August 2016 - 11:09 AM
It is a pig, and RedRuby's advice is spot on
Posted 01 August 2016 - 06:44 PM
Getting ready to do this replacement on my pre-verto. It looks to be much easier with far fewer removals that what is on the verto checklist.
Posted 01 August 2016 - 09:27 PM
Pre-verto slave cylinder is quite straightforward, assuming nothing has seized up. Like, for example, the nut fitting the hose to the bulkhead - had to cut off the one on my Marcos last week as they were rusted solid. Fortunately I'd bought a braided hose when I got the slave cylinder and was planning on replacing it anyway...
Posted 05 August 2016 - 05:32 PM
So my advice is unbolt the brake master from the servo first (not any pipework) and its an easy job then to change the clutch slave. No need to remove anything else.
Edited by great68, 05 August 2016 - 05:41 PM.
