Calipers Z-Cars
14 replies to this topic
#1 wim
wim
    Starting My Mini Up
  • 4 posts
Posted 27 August 2016 - 09:28 PM
Hi All,
I try to find out which calipers fit on the Z-cars trailer-arms (see attachment).
Up to now I didn't succeed to get the right answer.
So I give it a try again.
I really would appreciate to hear from you which one will fit.
Regards Wim.
#2 Jayme 1275
Jayme 1275
  • 488 posts
Posted 27 August 2016 - 11:13 PM
I cold be wrong, but did they not use ford sierra calipers?
#3 Normal
Normal
  • 14 posts
Posted 28 August 2016 - 06:46 AM
On my Volvo kit it's Renault Clio RS1 1.8 RSI or Clio 1 2.0 Williams.
But my rear trailing arms are not as yours (not tubular)
#4 Pete649
Pete649
  • 371 posts
Posted 28 August 2016 - 07:24 AM
I think the ones fitted to mine were Ford Sierra.
#5 26dtp
26dtp
  • 42 posts
Posted 28 August 2016 - 07:39 AM
If calliper is Sierra does that mean hub and rotors are sierra also?
#6 Normal
Normal
  • 14 posts
Posted 28 August 2016 - 07:51 AM
No i have Ford Mondéo hub with Renault calipers...
#7 26dtp
26dtp
  • 42 posts
Posted 28 August 2016 - 08:02 AM
Right but for the older setups which use sierra calipers im wondering if the hubs and rotors are sierra also.
#8 quagmire
quagmire
  • 74 posts
Posted 28 August 2016 - 05:15 PM
Need some cv joints/stub axles for mine (box type arms) would they be Mondeo? I know there are different sizes for diesel and petrol models will have to measure the splines on my drive flanges?
#9 quagmire
quagmire
  • 74 posts
Posted 29 August 2016 - 12:02 AM
My calipers will get better images tomorrow
#10 Stephenhasting
Stephenhasting
  • 21 posts
Posted 29 August 2016 - 08:16 AM
My hubs that I bought were off the front of a mondeo mk1. The number is 19090 and they're febi bilstien ones. I went to a local scrappy to get some temporary cv joints for mine to hold it together and they were also off a mk1 mondeo. Pretty sure it was a 2.0 diesel but I think they're all the same anyway. Hope this helps
#11 quagmire
quagmire
  • 74 posts
Posted 29 August 2016 - 08:34 AM
Thanks for that Stephen as it happens I have a old Mondeo as my daily driver so I could measure the splines on it and check against the drive flanges on the mini. Was going to get some from a scrappy myself so I could get some wheels on and be able to move the car around more easily. Have read that there pretty awkward to to split from the drive shaft though?
#12 dondo
dondo
  • 128 posts
Posted 29 August 2016 - 01:19 PM
This is what is on mine hope it helps
Rear Brakes Wilwood four-pot calipers 265mm vented and drilled rear discs. Sierra rear calipers for the hand brake ( John the builder of my car does not list what year it came from)
Took the wheel off and have taken some pictures.
rubbed off the paint in the caliper to bring up the number stamped on it (67321 051/6)
Edited by dondo, 29 August 2016 - 01:21 PM.
#13 quagmire
quagmire
  • 74 posts
Posted 29 August 2016 - 04:38 PM
Wim,the calipers on my mini are different from the ones on dondo,s. So they could be the Renault items mentioned earlier sorry I can't be more helpful
#14 Stephenhasting
Stephenhasting
  • 21 posts
Posted 29 August 2016 - 10:43 PM
Dondo has a larger braking setup than the 'standard zcars' as these never had vented discs unless the kit has been changed by the owner to suit taste. I also have a rear vented disc on mine to match the front but don't use two calipers. Just one that does brakes and handbrake as a 4 pot on the rear is way too much unless a pressure/flow control has been used to differentiate it from the front.
#15 quagmire
quagmire
  • 74 posts
Posted 30 August 2016 - 02:15 PM
Just been on to My mate at the motor factors apparently there are two sizes for mk1 mondeo cv joints one for petrol engines and one for diesel. Anybody know which one I need? not sure if the splines are different or the actual bearings that take the drive shaft, don't want to get the wrong one and not be able to fit the drive shafts when I eventually get them
Thanks john
