Switched Boot Light
Posted 28 August 2016 - 11:29 AM
Posted 29 August 2016 - 03:39 PM
You can extend the purple/orange wire to the interior light, (which is a live feed) along the roof rail, down the "C" post into the boot. This goes to one side of the light, then wire from the other side of the light to a door switch operated by the boot lid, then other side of door switch to chassis. (The door switch may be earthed through the fixing screw depending on type). If you stick LED strips on the underside of the parcel shelf these make an ideal light as they are very slim and you cannot see them without "Limboing" under the parcel shelf.
Edited by Compdoc, 29 August 2016 - 03:40 PM.
Posted 29 August 2016 - 08:42 PM
