if the car is running bit rich does that loose power and torque
If Car Running Rich
racingbob
, Aug 29 2016 08:06 PM
4 replies to this topic
Posted 29 August 2016 - 08:06 PM
Posted 29 August 2016 - 08:10 PM
Yup rich is safer then lean though
Posted 29 August 2016 - 08:46 PM
both are bad lean over heats and burns things rich washes the oil off and you blow it up
Posted 29 August 2016 - 09:09 PM
Only in the extreme. Slightly rich won't cause bore wash.
Posted 29 August 2016 - 09:43 PM
The more fuel you add, the faster the bores and rings wear. The trick for optimum fueling on a road car is only add enough fuel to avoid misfire at part throttle, and only add enough full at full power toacheive full power and no more. No where should it be rich. Rich running has no place in a road based high mileage engine.
Ac
Ac
