hi all. have a early mk3 inner column with the cancelling stud, unfortunley the internal splines at the bottom have worn and needs to be replaced. was just going to buy the post 85 column, drill and tap for the cancelling stud and trim the bottom of the outer column? has anyone done this conversion successfully?
3 replies to this topic
Posted 01 September 2016 - 08:26 AM
Posted 03 September 2016 - 04:11 PM
Do you have the early type Mk3 steering lock fitted?
I can't remember if this works with the later inner column, others may be able to help on this point.
Posted 03 September 2016 - 08:53 PM
I might be off the mark here, but I think the later columns were longer. If I remember today, I'll check.
Posted 04 September 2016 - 12:25 PM
no steering lock fitted.
cheers
Also tagged with one or more of these keywords: suspension
Mini Technical Sections →
Problems, Questions and Technical →
Mot Advisories On Potential PurchaseStarted by billlifferr , 12 Jun 2023 suspension |
Fitting 10” Wheels On My Mini Convertible (Spi)Started by Dalla , 29 May 2023 suspension, brakes |
Radius Arm - Reaming Or Beyond Repair?Started by Chelsea_Pete , 04 May 2023 suspension |
Correct Upper Suspension Arm Tightening Process?Started by Dakinn , 03 May 2023 suspension |
Track Rod End Thread Engagement / Adjustable Lower ArmsStarted by YankWithAMini , 02 May 2023 suspension |
