Removing Rear Drum Offside As Adjuster Rounded Off
Posted 02 September 2016 - 07:28 PM
Posted 02 September 2016 - 07:43 PM
The bit in the centre is just a cover.
Heat and penetrating oil and some mole grips will loosen the adjuster
Dust cover.
Posted 02 September 2016 - 08:00 PM
As Nick has said, you will need to move the adjuster and you'd be best off replacing it. If that is what you are going to do, don't weld a nut on it as then you won't be able to get it out, they screw in (as in towards the inside of the drum) to get them out.
Try Plusgas and then use vice grips to get the old one moving.
Posted 02 September 2016 - 08:21 PM
You just need to remove that metal "strap" which on many old cars is rusted away any way.
Posted 25 October 2016 - 03:44 PM
I have welded a bar to the adjuster, and have then been able to get it moving.
When it has moved and is freely moving, I have then cut the end of the adjuster off where it was welded.
Also tagged with one or more of these keywords: brakes, suspension, engine, electrical
Mini Technical Sections →
Problems, Questions and Technical →
Piston Rings - A-Series 998 Engine - Help RequiredStarted by WanaGo , 18 Apr 2024 engine |
Exhaust Choice 45Dcoe - Rc40?Started by lachlan1275gt , 13 Apr 2024 engine |
1071 Main Bearing Caps.Started by 246jaenick , 02 Apr 2024 engine |
Misfire - Ignition Fault Or Fuel Problem?Started by derekaka2sheds , 01 Apr 2024 electrical, engine |
Which Rocker ArmsStarted by mark the diver , 30 Mar 2024 engine |
