Engine Number Query
7 replies to this topic
#1 DJS911
DJS911
  • 240 posts
Posted 28 September 2016 - 06:52 AM
Hi guys,
When my son bought his '73 Mini car there was no engine plate on the block. The rivets are still in place but the plate would appear to have just rusted away.
The engine is a later A + series but yesterday we found a number stamped into the block under where the plate would sit.
It took quite a bit of delicate use of the Dremel but the number is 131391 and it is located on the RHS of the flat where the plate would sit.
Anyone got any idea of what this number is?
We have an engine number on the V5 which is for a 998 A+ but that bears no resemblance to to 131391.
Thanks in anticipation.
#2 dyshipfakta
dyshipfakta
  • 1,696 posts
Posted 28 September 2016 - 07:44 AM
My gut feeling is that it's a 1310 ish overbore engine built in 1991
Edited by dyshipfakta, 28 September 2016 - 05:03 PM.
#3 nicklouse
  • 17,944 posts
Posted 28 September 2016 - 08:03 AM
post up pictures so the engine can be IDed as small or large bore to start with.
and the number could mean anything. but is the rivets are original then the engine is most likely to be standard as you need to remove them to work on the block.
#4 DJS911
DJS911
  • 240 posts
Posted 28 September 2016 - 08:42 AM
Thanks so far guys. Below are a couple of photos that hopefully will help.
Nick - when I said that the rivets are still there perhaps what I should have said is that there is metal in the holes in the block where the rivets go but this is flush with the block!
Attached File  Engine 01.JPG   74.01K   23 downloads
Attached File  Engine 02.JPG   78.23K   15 downloads
Edited by DJS911, 28 September 2016 - 08:49 AM.
#5 DJS911
DJS911
  • 240 posts
Posted 28 September 2016 - 02:42 PM
FWIW I've followed the flow chart on the Mini Mania website to identify the engine and it confirms it as a non-Cooper 998.
I'd still love to know what the stamped numbers mean though!
#6 nicklouse
  • 17,944 posts
Posted 28 September 2016 - 03:00 PM
that is just a later A+ 998 with verto clutch from after 1980.
#7 DJS911
DJS911
  • 240 posts
Posted 28 September 2016 - 03:44 PM
Thanks Nick - any thoughts on the reasoning behind the numbering under the engine plate?
#8 nicklouse
  • 17,944 posts
Posted 28 September 2016 - 09:26 PM
Nope. Maybe someone at some time just needed a number to keep someone happy like insurance or.....
Or there were the engine number after the description letters that the then owner thought it might be good to put on it.
