Monza Fuel Cap Removal
5 replies to this topic
#1 michal
michal
  • Just Joined
  • 187 posts
  • Local Club: Mini Clan
Posted 28 September 2016 - 07:44 PM
Having problem with fitting monza style fuel cap. Managed to fit threaded ring on fuel tank neck with rubber mallet only to realise that the chrome part takes only two or three turns before gets stuck. Any advice on how to remove threaded ring to come back to original cap?
Sliding hammer with hook attachment?
#2 Baldspeed Racing
Baldspeed Racing
  • 1,185 posts
Posted 29 September 2016 - 06:36 AM
I use a rubber mallet to get the main cap on n off, to release the threaded ring either a puller or flat chisel under the ring, a good cloth over the seam and gently tap away until it releases
#3 Chris Donaldson
Chris Donaldson
  • 81 posts
  • Local Club: ISMOC
Posted 01 October 2016 - 07:00 PM
I spent a lot of time researching this exact subject. My dad had a full respay to get a concours finish on a car and was concerned that to maintain that we would have to take the arches off every now and again to have them sprayed as the enivitable odd stone chip happens. The only way to get the arches on an MPI off is to remove the tank and to do that you need the ring off. Having spoken to a few people on here and spoken to mini spares and mini sport, including talking to a mechanic at mini sport the answer kept coming back as....... cut it off with a hack saw. The ring is available as a separate part for a couple of quid so a replacement part is needed.
#4 michal
michal
  • Just Joined
  • 187 posts
Posted 03 October 2016 - 07:57 PM
I spent a lot of time researching this exact subject. ....... cut it off with a hack saw. The ring is available as a separate part for a couple of quid so a replacement part is needed.
had a quick look on minispares and you can get full kit for around 17 and ring only for 15 :-/
#5 michal
michal
  • Just Joined
  • 187 posts
Posted 05 October 2016 - 08:07 PM
I spent a lot of time researching this exact subject. . Having spoken to a few people on here and spoken to mini spares and mini sport, including talking to a mechanic at mini sport the answer kept coming back as....... cut it off with a hack saw.
Managed to remove it with a sliding hammer. Took only a couple of minutes :-)
#6 dyshipfakta
dyshipfakta
  • 1,696 posts
Posted 06 October 2016 - 05:43 PM
Well done that man. Would drill it tap it and got some grub screws. That's how mine is held on.
