I'm on with restoring my 1275gt into bit of a retro rally car spec.
I have a choice of a few bit I have in my garage to make a good engine for it.
My plan is to have a fun car just for going for a blast every now and then down country roads general hobby car.
It wont be used for commuting or long distance driving!
I have a few choice of parts and would like to know whats best to put together a fun engine for this car.
I have a 1293 A series that need a rebore with 731 cam and 12g1805 head,lightened flywheel,back plate with orange clutch (pre-verto) and 1.5 high roller rockers.
Also got an A+ engine that's standard 1275 with 12g1817 crank and 530 kent cam with mg metro head.
What I want to know is whats best way to go with my choices?
I have got a set of +40 thou flat top pistons to go in either block or put 1293 (dished +20thou) into A+ block and go from there???
Dont mind getting either block or both rebored and happy to buy new bearings and re-balanced crank.
Should I get centre main strap also fitted to which ever I build?
Other add ons I have are set of twin 1 1/2 Su's and LCB,Servo brakes with mg 4 pot calliper, vented disc's fitted and rear mini fins.
I would like to stick with the A series engine as its more in keeping with the car,but is there any pro's or con's for having A+ with verto clutch?
Lastly was thinking of buying Aldon electronic ignition for engine and adjustable timing gear for cam drive.
Any opinions on buying either?
Cheers tim
