Midas Gold Black
38 replies to this topic
#16 nicklouse
  • 17,945 posts
Posted 25 January 2017 - 09:20 PM
The box. Nothing special. X pin dif and baffle.
329D0B42-2A49-4B48-83D2-64F3A3F0E536_zps
#17 nicklouse
  • 17,945 posts
Posted 25 January 2017 - 09:32 PM
Now we need to remove the race from the transfer case.
Recently there has been a video showing some Russians useing bread to remove a race. Nothing new but I have always used grease and maybe some paper.
First remove the C ring
8A90EAD2-033C-41A9-BE6F-0D9A1579234F_zps
Find a socket that just fits inside and fit it inverted to an extension. Then place some paper inside and then fill with grease. Insert inverted socket into the race and hit sharply. Note the grease streak which came out of an oil way. The paper helps reduce.
FDECE1D2-3604-41A4-803E-3A17474C761C_zps
And Bobs your uncle.
0C0A8CE9-AA8C-478D-9CBC-BD07402B3AC3_zps
If you are going to use a blind bearing puller you can see the cut out to allow the legs under the race in the first image.
Don't forget to clean out the oil ways.
#18 MrBounce
MrBounce
  • 2,563 posts
Posted 29 January 2017 - 10:15 PM
I like that trick Nick!  :thumbsup:
#19 nicklouse
  • 17,945 posts
Posted 29 January 2017 - 10:48 PM
And for my next trick a freezer and either an oven ot just a hot air gun.
#20 nicklouse
  • 17,945 posts
Posted 07 February 2017 - 10:31 PM
Got started on Sunday.
6C246305-7705-43B1-A779-8872D16B58B6_zps
A290CF86-967B-494C-AB76-21F4CFCCA5BC_zps
B71E293B-F473-49A1-85AD-2C1A06013FCF_zps
Then it was a check what was missing. Those are ordered and should be here soon.
Next job will be marking up the damper with a timing notch. Just waiting for the cover to be cleaned up.
#21 nicklouse
  • 17,945 posts
Posted 11 February 2017 - 09:34 PM
Today was adding a timing mark to the crank damper pulley.
F4315B88-D2CE-4906-992A-626B0A8F1BCD_zps
Damper will need to come off again so I can torque the bolt down when the flywheel is back on.
Put some more bits on.
40D8160B-44EA-45C8-8A48-0D6FF98DA410_zps
#22 nicklouse
  • 17,945 posts
Posted 12 February 2017 - 07:10 PM
Today was mainly trying to take out the blower motor. I have seen some bodges before but ......
Engine wise pulled out the metalastic bush for the gear change. New one should be here next week. The ones I thought were for are too big.
Here is a how to get the bush out.
3D5030A4-1E9D-468D-953B-6EF1F442F5A9_zps
Then it was onto cleaning out the insides of the manifold. Stripping and cleaning the carb as the jet was stuck.
#23 nicklouse
  • 17,945 posts
Posted 14 February 2017 - 11:17 PM
Helicoil kit on the way.
Why do people force steel studs into alloy parts?
Also interesting to see the different bore sizes on the MG inlet. Soon have that sorted.
Missing bits have arrive. And bling ordered. Should be in on Sunday.
#24 nicklouse
  • 17,945 posts
Posted 15 February 2017 - 08:10 PM
Nice packaging.
E4A8DAEB-336B-41BD-ADFF-56BBAB3158CB_zps
D5B94A59-AA32-4C42-BB41-5E7A8D0FC488_zps
#25 nicklouse
  • 17,945 posts
Posted 17 February 2017 - 12:43 AM
AD3CB66C-2254-4092-8A15-9EB9A84208DA_zps
53B33D20-B27C-4D95-A1FA-01AC79E9EAC8_zps
Well that was simple enough.
#26 nicklouse
  • 17,945 posts
Posted 18 February 2017 - 09:58 PM
Time to fit the new bush.
2D379C5A-5FC7-4CB4-BC00-BD4B4083C9A4_zps
First a small chamfer.
8FD97D85-6882-43B7-8C53-38E08A5C565C_zps
Press home.
E9809AA0-2C14-4AFD-9CA9-3E6D9A1DFB93_zps
279742C3-A85F-46C6-B5A8-480C61F58864_zps
Loads more done but no pictures.
#27 nicklouse
  • 17,945 posts
Posted 19 February 2017 - 09:41 PM
And back in the car.
2AB98A37-8035-4298-8FFA-4B6178AD1590_zps
#28 nicklouse
  • 17,945 posts
Posted 20 February 2017 - 08:48 AM
should also  mention that we changed the knuckle joints.
did you know that to undo the top shock mount you need to take out the dash!  not the best design.
#29 MrBounce
MrBounce
  • 2,563 posts
Posted 20 February 2017 - 12:55 PM
Can't be as bad as replacing the captive bolts for one half of the top shock mounts on my Mk1. You had to go in via the subframe tower bolt hole. It takes AGES!
#30 nicklouse
  • 17,945 posts
Posted 26 February 2017 - 06:49 PM
Arrrrggghhhhhh
5FC5547F-E9AA-4655-BE50-5E4FECC5A1F3_zps
Spreading the yoke so the linkage will fit.
All back together and connected.
Has fuel and spark but not starting yet.
Strobe on it next weekend.
