I drained the oil out of an engine today and all the bit's on top of the steel in the photo came out, the holes drilled in the metal the bits are on are 5mm diameter. the largest bit of metal is 1mm thick. The engine ran pretty much fine when we drove it home ages ago. so we've stripped the engine from the gearbox to try and see what could be the problem, but from what we can see there isn't one. I think the head has been off/ changed in the past, but not sure if the GB has be split.
It's a 998 from a 1982 car.
I know it's not much to go by but does anyone have any ideas what it could be from or where to look in the engine? Could it just have been a bit of metal accidentally dropped in and missed?
