The entire Concorde was drawn by hand. I worked on the design of the droop-nose mechanism and the retracting visor structure.
The visor had a large centre spine with very complex machining. It was to be milled using the then-new Computer Controlled Machining process, so my manual drawing had to be converted into a machining programme and I spent hours working with a CNC programmer/production engineer to create the programme with minimum modifications to my basic design. All that overtime paid the deposit for my first house .
I once worked on the installation design for an aircraft called the BAC167 Strikemaster. It had an up-rated and larger engine. Using log tables and a drawing board it took me about 3 weeks at 40+ hours per week to evolve an installation geometry which would fit the airframe profile. I guess a CATIA CAD system would do it in about 2 days now and provide the load calculations in each mounting point.
