Update time... get comfy.....
thought i would test fit the rear subby before got too far into final welding...
this showed up a small hurdle of new poly bushes on the original subframe onto a genuine heelboard...
This was solved by the use of 2 large penny washers on the outboard of the bushes then shaving off the depth of the washers from the inner half bush of both sides, thus leaving still tension on the bushes but locating with a slight pry to locate the bolts with liberal use of copper grease on final assembly.
Following up with final little bits and pieces...
As you can see there were lots of pinholes where if it was anything but this build i would replace all the panels. however due to the ratty appearance im after plan b came in to play.... Im not a fan of this at all but long term plan is to do a steel flip front so in time these panes at the front will either be replaced of chopped off fro scrap so out came the fibreglass kit. and pretty much created a inner skin of fibreglass around the lower end of the front panel and behind the front lights to reduce the wind drag
Some painting of cavities next, at this point my excitement levels are through the roof after cutting grind and welding for nigh on 18months on this beastie the end is in sight...
Inner sills...
Valance closers...
And A panel flanges and back of outer sills and rear valance closed areas..
And the next morning came where my excitement levels reached a new high where i could hang up my welding torch for a few months until i continue with the special restoration....
OUTER SILLS!!!!!
and went to start the rear valance, got 5 plugs into it and, hmm these welds are looking very cavasious, oh bottoms, ran out of gas.. so up the welding shop for another refill and
shazam rear valance.
After that I spent an hour or so just dressing back some edges and welds ready for the next days toil of RAPTOR!!!
