A Pair Of 64 Mk1 850S
#61
Posted 07 June 2017 - 10:46 AM
#62
Posted 14 June 2017 - 07:43 AM
I finally got the A-post inner plate repaired. Al the edges were cleaned up and readied for spot welding. "Completely correct" alignment of the inner fender achieved and tested with surrounding panels and door, then spot welded where I could reach. Where I couldn't reach we drilled for plug welds. The top corner of the inner fender was cut to fit the already-installed replacement top corner (It fits between the windscreen frame and firewall plate, and thus already installed.) and welded. As yet needs cleaning of the welds.
The scuttle under-plate is now ready to install.
IMG_20170612_195736s by frogeye61, on Flickr
IMG_20170613_211539s by frogeye61, on Flickr
IMG_20170613_211658s by frogeye61, on Flickr
IMG_20170613_211722s by frogeye61, on Flickr
#63
Posted 21 June 2017 - 09:13 AM
Well, this Tuesday we took care of a number of smaller items.
Scuttle closing panel, though a bit hard to see in the photos. Used the spot welder on the front edge and full weld against the inner fender.
IMG_20170621_073814s by frogeye61, on Flickr
Repaired the rust behind the right side fender brace
IMG_20170620_194111s by frogeye61, on Flickr
I must say it still needs a bit of clean-up. It was after all Tim who did the welds and Peter who did the finishing.
IMG_20170621_073822s by frogeye61, on Flickr
The rear subframe braces aren't too bad, but need a bit of finishing.
IMG_20170621_073915s by frogeye61, on Flickr
Under-door panel is trimmed to fit the surrounding panels.
IMG_20170621_073946s by frogeye61, on Flickr
And the A post rear face is to be positioned correctly with relation to the door.
IMG_20170621_073957s by frogeye61, on Flickr
Productive evening, though I would like things to go a bit faster.
#64
Posted 26 June 2017 - 12:05 PM
Saturday I decided I should fit the left door. The surrounding pieces needed to be placed correctly onto the shell but no space to mount with mole grips, so I had to use tack welds for much of it. The foot step and A-post pillar covering were carefully measured and tacked together. Placement of these two within the door opening was much more a guess and try affair. Turned out to be only two iterations for a proper fit though.
IMG_20170624_161616 by frogeye61, on Flickr
All panels here are tacked or held with grips. Spacing is good. Door seal strip is installed most of the way around for proper distancing. Important here is that the bonnet, front wing, inner A-panel, door surround and door are within acceptable limits. Ready for epoxy primer inside the panels and welding in place.
IMG_20170624_163516 by frogeye61, on Flickr
Last week I found a very interesting vehicle for sale locally. So Sunday I went out to inspect. TOTAL ROT, Seized engine etc... this coming from me! Even after doing major rust on the Mini, Frogeye, Jeep, Amazon, Alfa etc etc. I thought it was too much money (~£1400) even though it looks reasonable from the outside and has all glass and interior.
IMG_20170625_182811 by frogeye61, on Flickr
IMG_20170625_182802 by frogeye61, on Flickr
#65
Posted 28 June 2017 - 08:58 AM
IMG_20170628_074547 by frogeye61, on Flickr
The right side inner wing is now in the beginning stage of installation
IMG_20170628_074501 by frogeye61, on Flickr
#66
Posted 28 June 2017 - 09:05 AM
You're making some good progress on this build. It's very cool to see.
#67
Posted 29 June 2017 - 11:48 AM
Thanks, I'm quite enjoying it.
With regards to the red Mini, I have received some floor repair panels and side bins, but haven't had too much time to work with it. After I hand-ground a speedometer gear I haven't done much with the engine... except it fell on my shin one time and scraped a bunch of skin off.
But I have been working on the front suspension. Subframe is cleaned and painted, as are the upper and lower suspension parts. The tough part was separating the front trumpets from the upper arms and especially the rubber springs. I had soaked them in WD-40 and Caramba-70 for several weeks with no luck. Then a big bashing with a hammer and they came off. The rubbers, though original are quite nice but probably hard. That's good isn't it? I couldn't get the suspension back together because I don't have a spring compressor, and since these are English threads it would require the more expensive unit. Neither do I want to buy new rubber springs. Too expensive. So I have some Hi-Los and knuckle joints coming along with some hoses, speedometer cable and a thermostat housing for the 1275 cooper. This being necessary for fitting the Metro motor into the round-nose body.
#68
Posted 03 July 2017 - 08:33 AM
Not too much work on the Mini this last weekend. You know, wife and house stuff.
I managed to repair the flanges which fit up to the right side front inner wing and the lowest extension of the inner part of the A-post. This last-mentioned part was butt welded to the good metal above and spot welded to the floor section.
IMG_20170702_175023 by frogeye61, on Flickr
The parcel shelf flange had been cut in half by one of the other guys when they removed the original inner wing. Don't do that! Cut clear of the parcel shelf!
IMG_20170703_074905 by frogeye61, on Flickr
#69
Posted 05 July 2017 - 02:00 PM
#70
Posted 06 July 2017 - 02:05 PM
#71
Posted 10 July 2017 - 02:14 PM
Sorry about progress on the Mini this weekend. Non existent. I finally got a chance to test drive the Frogeye.
Here are a few pics and a short film. My wife has a couple longer films but not up on the NAS yet.
#72
Posted 12 July 2017 - 10:34 AM
Sorry, no useful pictures from Tuesday evening.
We ran into a problem. While door is in correct position at the aft end, and the A-panel is mounted to hinges and therefore door, there comes a 10 mm gap to the front wing. The wing is clamped to the front panel, which is aligned to the bonnet and the wing is also aligned to the scuttle and the bonnet side. Measurements didn't enlighten us to the deviation.
I will continue researching the problem, which is likely to be a combination of deviations through several pieces, or that the vehicle had been damaged prior to the initial bracing being installed. Either way, progressing further will require some less-than-fully acceptable mods. Who knows? Maybe the discrepancy comes from the non-genuine panels we are using.
#73
Posted 17 July 2017 - 01:31 PM
#74
Posted 17 July 2017 - 03:05 PM
#75
Posted 19 July 2017 - 08:17 AM
We finally got the A-panel mounted, aligned and welded in place. The door fits fine and despite the appearance in this photo, it really does fit at the bottom.
IMG_20170715_160303 by frogeye61, on Flickr
IMG_20170715_160334 by frogeye61, on Flickr
The yellow appearance is a reflection of something behind me. The inner A-panel is covered in rust protection.
IMG_20170718_201749 by frogeye61, on Flickr
IMG_20170718_201805 by frogeye61, on Flickr
Welds are ground reasonably smooth.
IMG_20170718_201755 by frogeye61, on Flickr
The rusty metal at the bottom of the right rear door surround is removed in favour of a new door step.
IMG_20170718_201818 by frogeye61, on Flickr
Problem is that the replacement door step is shaped wrongly.
IMG_20170718_205542 by frogeye61, on Flickr
Though no picture, I beat the corners into the correct shape and it looks superb. It fits the door very well with good door gap all along. Tonight I will weld this piece in place.
