Hi all,
Hoping someone can help, I had a bulb go in one side of my side repeaters. I used the good bulb to make sure that both sides worked independently which they did so I bought new bulbs for it and now neither side works ....
Anyone got any ideas need to get them working for an MOT
Thasks!!
4 replies to this topic
Posted 20 November 2016 - 01:36 PM
Posted 20 November 2016 - 01:56 PM
So check them again. Check the bulbs.
Posted 20 November 2016 - 02:05 PM
Yeah 1st thing I did was check them make sure they hadn't blown or anything there doesn't seem to be anything wrong with the bulbs
Posted 20 November 2016 - 02:18 PM
I would also check / clean up the bulb contacts as that area under the wing get lots of muck sprayed at it by the wheels. Other thing would be to have the ignition and indicator on and wiggle wires / bulb to see if it does start to work, that would indicate a poor contract / broken wire.
Posted 20 November 2016 - 02:23 PM
Thanks I'll do those and give it a try and see how I get on. Thanks!!!
Mini Technical Sections →
Problems, Questions and Technical →
Misfire - Ignition Fault Or Fuel Problem?Started by derekaka2sheds , 01 Apr 2024 electrical, engine |
Mini Spi Charging IssueStarted by Dutch_MiniSPI , 27 Mar 2024 electrical |
Main Dipped Beam Not Working - Just Before Mot :-(Started by Park , 24 Mar 2024 electrical |
Speeduino EcuStarted by cooperpooper , 09 Mar 2024 electrical, engine |
Smiths Electronic Speedo Accuracy?Started by chuee , 01 Mar 2024 electrical |
