Mpi Radiator Fan Not Cutting In
38 replies to this topic
#31 pete l
pete l
  • 1,360 posts
Posted 23 September 2020 - 02:23 PM
I would start by replacing the expansion cap with a GENUINE one. They leak pressure and allow the coolant to boil up.
I have heard that BINI ones are good to use.
#32 Quinlan minor
Quinlan minor
  • 992 posts
  • Local Club: LSMOC
Posted 23 September 2020 - 07:11 PM
Hello all  & @Netish -
2001 MPI here
I've drained the system and replaced thermostat with 82 degrees.
Any help would be very welcome.
Should be an 88° in an MPi.
#33 Rusty Nut
Rusty Nut
  • 21 posts
Posted 23 September 2020 - 08:59 PM
I’ve replaced the cap with a new one. The 82 is because it’s warmer here in the south if France than in the uk.
should I stick with the stock? Or maybe run stock in winter?
#34 Quinlan minor
Quinlan minor
  • 992 posts
  • Local Club: LSMOC
Posted 23 September 2020 - 09:35 PM
An injected engine runs more efficiently at the higher temperature. Never had any cooling problems here, in London, at 35°+ with an 88° Thermostat.
#35 pete l
pete l
  • 1,360 posts
Posted 24 September 2020 - 09:20 AM
Where did you buy the new one from ? I bought 3 from the little mini shop in France and they all leaked pressure. Ended up buying them from DGMRS in the UK, original and don't leak.
#36 Rusty Nut
Rusty Nut
  • 21 posts
Posted 24 September 2020 - 12:08 PM
Ok I’m going back to 88 and fingers crossed that a new temp sender unit works better than mine does now.
I thought 82 might solve my problem but understand that the MPI’s are more efficient if run at the temp they were designed for.
The replacement came from  Minispares.
just a question - did they make the 74 and 82 degree stats for older normally aspirated cars in hotter climates?
#37 Honda-Mini
Honda-Mini
  • 124 posts
  • Local Club: Cornish mini club
Posted 28 September 2020 - 10:53 AM
Rusty nut...i had the same issues and tried absolutely everything...
changed the cap three times and all were useless it turned out, even though i was convinced it couldn't be that... final straw came when i bought an ACR4 in the end and found one cap was only getting to around 96º before it started to expand and boil over... the next new cap i fitted got to 104º and just started blowing a bit so i stupidly went to tweak it down a touch to stop it and it blew off, scalding my forearm in the process...
luckily i wasn't directly over the coolant tank and had obviously used a large towel for heat, so that saved me really or i reckon id have been hospitalised/blind by now!... Lesson Learned!!
anyhow, i think it was on here someone said get one of these... https://www.ebay.co....S4aArGIEALw_wcB
fitted it (and also changed the expansion tank to and R53 one as mine had ballooned so many times it looked weak and a new one is silly money, whereas an R53 is cheap and same outlets :) ) and not looked back since...
Change the Cap for a Volvo S60 one and you will be good to go... it is turquoise ish but if you look on the Bay they do come in black to make them a bit less obvious
heres some links to my posts on it
http://www.theminifo...g-on/?p=3620387
http://www.theminifo...expansion-tank/
HTH
Martyn
Edited by Honda-Mini, 28 September 2020 - 11:00 AM.
#38 Rusty Nut
Rusty Nut
  • 21 posts
Posted 28 September 2020 - 12:50 PM
OK many thanks for that Martyn.
I'll look into it. Daughter has just bought a old R50 and wife has the R56 so should be not too difficult to figure out.
I heard that the R50 bottles can split too - known problem.....but at least they'll be cheap.
I'll report back
thanks again
Rusty
#39 Honda-Mini
Honda-Mini
  • 124 posts
Posted 26 January 2021 - 10:06 PM
I'll report back
thanks again
Rusty
So, have you had chance to look at it yet? If so how’d you get on?
