Tucked Wiper Motor Help
Posted 06 December 2016 - 11:33 PM
Turns out the owner was able to tuck his wiper motor
Away from the engine bay for an ultra clean look
Does anyone know which wiper motor to use and where to put it so it's away from the engine compartment ???
Thx IMG_8833.PNG 223.39K 126 downloads IMG_8833.PNG 223.39K 126 downloads
Posted 06 December 2016 - 11:57 PM
Posted 07 December 2016 - 02:04 PM
With a bit of thought, the motor can be mounted on the 'cabin' side of the bulkhead and the bundy tube taken through a hole to get to the wiper boxes
Posted 08 December 2016 - 02:07 AM
does the tube need any kind of extension ??
Posted 08 December 2016 - 09:07 AM
depends on where you mount the motor. note if you change the length of the outer you will need to change the length of the inner drive cable.
Posted 08 December 2016 - 10:42 PM
Posted 08 December 2016 - 11:38 PM
Posted 09 December 2016 - 08:11 AM
Posted 09 December 2016 - 08:15 AM
😀 I read all of them so it's a bit fuzzy to which one...
Posted 09 December 2016 - 09:20 AM
Google 'wiper drive rack' or 'wiper drive cable' and there are companies that will supply cut to length. e.g. www.johncraddockltd.co.uk
Places like www.europaspares.com also do wiper kits.
Posted 09 December 2016 - 10:48 AM
Posted 09 December 2016 - 11:11 AM
Posted 09 December 2016 - 06:15 PM
CBS have lots of wiper parts which may be useful.
http://www.carbuilde...=grid&orderBy=0
You may need some kind of flaring tool to make the outer tubing ends. The inner drive rack is continuous, just cut to length.
Or you can get independent motors like this:
http://www.carbuilde...5-degrees-black
Another possibility, needing LOTS of work. My daily driver, Ford S-Max, uses two independent motors which are synchronised through the central computer. They work in opposition. The pivot points are out at the corners of the screen, and one arm is joggled so it lies above the other when parked.
Posted 09 December 2016 - 06:58 PM
You can't.
We sell the outer tube, and the inner cable at Somerford Mini
